XM708 under roof now
JimC
Post by JimC »
Which will make working on it easier.Going to remove the rear tires tomorrow and begin the refurbishing of the rims.
Re: XM708 under roof now
Rare indeed-she'll be a beauty when you get her roadworthy!
JimC
Post by JimC »
Hopefully sometime next spring or summer
New left front axles arrive Saturday. I didn't order a tracta joint yet.
Will wait on that until I disassemble and check out the condition and clearance of the old one (from memory, 7 thousandths max, but I need to confirm that). And won't do the disassembly till I get the new rear tires mounted and off the jacks. I think I may use this as an opportunity to pull the front pumpkin and check out the condition of the bearings and ring & pinon.
I'm tired of looking at the beat up front bumper, so will install the winch bumperettes for the LU-4 this weekend.
I did pick up a new 4 psi radiator cap today
JimC
Post by JimC »
Trial fit today.
Studio_20251019_144519 (1).jpg (62.55 KiB) Viewed 179 times
You might pull one of those bumperettes before setting in the winch. Driver's side. I just did that with mine-too difficult with both in place. You'll also want to slide the PTO shaft in place before mounting the winch as well.
