1954 M37 rebuild thread
Re: 1954 M37 rebuild thread
I can almost smell it!
Happy New Year,
DSC01480 (Small).JPG (109.04 KiB) Viewed 3323 times
DSC01483 (Small).JPG (120.82 KiB) Viewed 3323 times
DSC01484 (Small).JPG (118.61 KiB) Viewed 3323 times
working on hood
DSC01485 (Small).JPG (81.2 KiB) Viewed 3323 times
On the bottom of the hood I found this
Compression numbers?
Hood is coming back, I wonder what caused the flaking/potato chipping, improper prep maybe?
DSC01490 (Small).JPG (118.96 KiB) Viewed 3280 times
Got my steering column finished
got the electric fan installed
DSC01491 (Small).JPG (119.66 KiB) Viewed 3280 times
DSC01489 (Small).JPG (122.32 KiB) Viewed 3280 times
Beautiful!
DSC01498 (Small).JPG (107.69 KiB) Viewed 3232 times
DSC01497 (Small).JPG (99.47 KiB) Viewed 3232 times
Hood done! Even got my thermal diffusers installed.
NCM
Post by NCM »
Looks good. Are the thermal diffusers ties to anything specific or do they just dissipate engine heat from under the hood?
NCM wrote:Looks good. Are the thermal diffusers ties to anything specific or do they just dissipate engine heat from under the hood?
With the hemi under the hood, heat removal is the objective.
RCrombie
Post by RCrombie »
They will probably help some with the heat after shutdown, but I imagine with the mechanical fan and the open underside to the engine bay there should be plenty of airflow while the engine is running. Did you make those vents or are they from another application? Either way, they look good.
DSC01503 (Small).JPG (98.17 KiB) Viewed 3201 times
DSC01500 (Small).JPG (87.19 KiB) Viewed 3201 times
The vents came off of some kind of military vehicle, had screens under them- bought them on ebay.
DSC01509 (Small).JPG (112.77 KiB) Viewed 3184 times
DSC01505 (Small).JPG (105.83 KiB) Viewed 3184 times
DSC01504 (Small).JPG (127.79 KiB) Viewed 3184 times
The really hard and tedious part.
DSC01518 (Small).JPG (91.19 KiB) Viewed 3148 times
DSC01520 (Small).JPG (136.58 KiB) Viewed 3148 times
DSC01519 (Small).JPG (128.54 KiB) Viewed 3148 times
Starting to look like a truck again!
DSC01537 (Small).JPG (124.45 KiB) Viewed 3122 times
Hood is on!
DSC01538 (Small).JPG (115.34 KiB) Viewed 3122 times
Here is how I managed to extract the bottom seal screws- lots of kroil and patience--all came out.
