1954 M37 rebuild thread
Re: 1954 M37 rebuild thread
I can almost smell it!
Happy New Year,
Happy New Year,
Compression numbers?
Hood is coming back, I wonder what caused the flaking/potato chipping, improper prep maybe?
Got my steering column finished
got the electric fan installed
- DSC01491 (Small).JPG (119.66 KiB) Viewed 3276 times
- DSC01489 (Small).JPG (122.32 KiB) Viewed 3276 times
Beautiful!
Hood done! Even got my thermal diffusers installed.
Looks good. Are the thermal diffusers ties to anything specific or do they just dissipate engine heat from under the hood?
With the hemi under the hood, heat removal is the objective.NCM wrote:Looks good. Are the thermal diffusers ties to anything specific or do they just dissipate engine heat from under the hood?
06boblee wrote:With the hemi under the hood, heat removal is the objective.NCM wrote:Looks good. Are the thermal diffusers ties to anything specific or do they just dissipate engine heat from under the hood?
They will probably help some with the heat after shutdown, but I imagine with the mechanical fan and the open underside to the engine bay there should be plenty of airflow while the engine is running. Did you make those vents or are they from another application? Either way, they look good.
The vents came off of some kind of military vehicle, had screens under them- bought them on ebay.RCrombie wrote:06boblee wrote:With the hemi under the hood, heat removal is the objective.NCM wrote:Looks good. Are the thermal diffusers ties to anything specific or do they just dissipate engine heat from under the hood?
Here is how I managed to extract the bottom seal screws- lots of kroil and patience--all came out.
