1954 M37 rebuild thread
- W_A_Watson_II
Re: What do you think?
No bad at all, a nice lower profile assembly. Where did you find it?
They are all over on ebay- where I got mine.W_A_Watson_II wrote:No bad at all, a nice lower profile assembly. Where did you find it?
The rubber isolated bulb module is pretty neat, with terminals for wires.
- DSC00942 (Small).JPG (114.25 KiB) Viewed 28204 times
- DSC00941 (Small).JPG (116.44 KiB) Viewed 28204 times
- DSC00943 (Small).JPG (112.61 KiB) Viewed 28204 times
- Site Admin
The orange section is always set outboard as it's the trafficator in other countries, you can still use it as the same and fit a red led in that position to suit your local DOT requirements.
MM
MM
Trained Monkey on Guard
dodgem37@netspace.net.au
wow! that looks great! im not a fan of aftermarket but they work well and don't look out of place
- W_A_Watson_II
Thanks. What is the black cylinder with the red sticker?
There is a bulb in it, for blackout conditions I guess.W_A_Watson_II wrote:Thanks. What is the black cylinder with the red sticker?
They look great, the profile is perfect too.
Well, I added some backup lights.
- DSC00955 (Small).JPG (110.45 KiB) Viewed 28100 times
- DSC00953 (Small).JPG (120.05 KiB) Viewed 28100 times
- DSC00952 (Small).JPG (127.62 KiB) Viewed 28100 times
I like the look and the fact that they're tucked up.
My WOW is becoming a W/eW
Adding a winch. The bracket fits inside the WOW bumper and is attached with existing bolt holes in framework. Winch is attached thru bumper and bracket.
- DSC00967 (Small).JPG (121.37 KiB) Viewed 28137 times
- DSC00968 (Small).JPG (132.74 KiB) Viewed 28137 times
- DSC00966 (Small).JPG (139.02 KiB) Viewed 28137 times
- PFC
Re: My WOW is becoming a W/eW
Is that a dodge branded winch?
Looks like it might be?
