1954 M37 rebuild thread
W_A_Watson_II
Re: What do you think?
Post by W_A_Watson_II »
No bad at all, a nice lower profile assembly. Where did you find it?
Will
1946 Dodge Power Wagon
My 1953 Dodge M37 WEB Site
W_A_Watson_II wrote:No bad at all, a nice lower profile assembly. Where did you find it?
They are all over on ebay- where I got mine.
The rubber isolated bulb module is pretty neat, with terminals for wires.
DSC00942 (Small).JPG (114.25 KiB) Viewed 28203 times
DSC00941 (Small).JPG (116.44 KiB) Viewed 28203 times
DSC00943 (Small).JPG (112.61 KiB) Viewed 28203 times
Monkey Man
Site Admin
Site Admin
Post by Monkey Man »
The orange section is always set outboard as it's the trafficator in other countries, you can still use it as the same and fit a red led in that position to suit your local DOT requirements.
MM
Trained Monkey on Guard
dodgem37@netspace.net.au
RMS
Post by RMS »
wow! that looks great! im not a fan of aftermarket but they work well and don't look out of place
W_A_Watson_II
Thanks. What is the black cylinder with the red sticker?
Will
W_A_Watson_II wrote:Thanks. What is the black cylinder with the red sticker?
There is a bulb in it, for blackout conditions I guess.
They look great, the profile is perfect too.
Well, I added some backup lights.
DSC00955 (Small).JPG (110.45 KiB) Viewed 28099 times
DSC00953 (Small).JPG (120.05 KiB) Viewed 28099 times
DSC00952 (Small).JPG (127.62 KiB) Viewed 28099 times
French Army Headlights.
just me wrote:French Army Headlights.
Good.
tinmedic
Post by tinmedic »
I like the look and the fact that they're tucked up.
My WOW is becoming a W/eW
Adding a winch. The bracket fits inside the WOW bumper and is attached with existing bolt holes in framework. Winch is attached thru bumper and bracket.
DSC00967 (Small).JPG (121.37 KiB) Viewed 28136 times
DSC00968 (Small).JPG (132.74 KiB) Viewed 28136 times
DSC00966 (Small).JPG (139.02 KiB) Viewed 28136 times
superbee70
Re: My WOW is becoming a W/eW
Post by superbee70 »
Is that a dodge branded winch?
Looks like it might be?
