Project M37a4
F18hornetm
Re: Project M37a4
Post by F18hornetm »
That is very cool. Great job on that M35 as well. Looks like neat work on that frame extension as well. :D
camoyj7
Re: Project M37a4
Post by camoyj7 »
More progress
m37 26.jpg (71 KiB) Viewed 20716 times
m37 28.jpg (61.18 KiB) Viewed 20716 times
m37 29.jpg (55.29 KiB) Viewed 20716 times
camoyj7
Re: Project M37a4
Post by camoyj7 »
Rough cuts to cabs.
m37 31.jpg (72.68 KiB) Viewed 20710 times
m37 30.jpg (68.11 KiB) Viewed 20710 times
Re: Project M37a4
Cool project and great progress. Keep the pictures coming.
chris olson
Re: Project M37a4
Post by chris olson »
Very inspiring.... i had thought about doing an extra-cab lengthening to my M37 but the crew cab looks really good
1952 M37cdn
Re: Project M37a4
M376x6 used to post here and had the dual axles but I don't think he made a crew cab on his-I recall he used a WC63 frame and worked the M37 body panels into that frame-looked very cool.
Monkey Man
Site Admin
Site Admin
Re: Project M37a4
Post by Monkey Man »
Brian Sage's 6x6 M37 had a longer, custom tray made from 2 M37 trays and the rear frame, suspension and maybe diffs of the vehicle were from a WC series 6x6 plus he had a 360 Cui V8 to get it mobile (very mobile I suspect!!). Brian has not been on here for a long time but you never know, he may chime in....
There was another pic of a dual cab M37 floating about, I think it had the longer type chassis and the tray was a cut down to size affair so I suspect it was made from a maintenance truck or similar.
MM
Trained Monkey on Guard
dodgem37@netspace.net.au
camoyj7
Re: Project M37a4
Post by camoyj7 »
Got the cabs joined up now just need to weld in supports and fill all of the gaps.
m37 32.jpg (58.19 KiB) Viewed 20618 times
m37 33.jpg (68.41 KiB) Viewed 20618 times
Monkey Man
Site Admin
Site Admin
Re: Project M37a4
It's looking good, mind you, and I am trying not to offend you but with that much length in added to the chassis it's turning radius will be shitful, maybe shorten the front of the tray a bit and bring those rear wheels back in closer to the back of the second cab or were you planning that anyway?
MM
camoyj7
Re: Project M37a4
Post by camoyj7 »
I am planning on shorting the frame that's why the rear half is still bolted together. it looks like I may take out 20" of frame. I didn't know how long the extra cab would be until I had it built that's why I made the frame rails extra long. I'm still going to use the full length bed.
Monkey Man
Site Admin
Site Admin
Re: Project M37a4
I can't wait to see the final shape, I guess the pictures and their perspective make the truck look overly long, I am sure you know what you are doing and after your large truck project you have all the kinks ironed out....
Keep this pictures coming :-)
MM
camoyj7
Re: Project M37a4
Post by camoyj7 »
Going to spend this weekend welding supports in cab and try to get new rear floors in.
m37 34.jpg (55.28 KiB) Viewed 20537 times
m37 35.jpg (60.56 KiB) Viewed 20537 times
camoyj7
Re: Project M37a4
Post by camoyj7 »
Took 17" out of the frame to get wheel base to match up with the stock bed.
m37 36.jpg (53.87 KiB) Viewed 20517 times
m37 37.jpg (60.36 KiB) Viewed 20517 times
m37 38.jpg (67.23 KiB) Viewed 20517 times
chris olson
Re: Project M37a4
After the stretch what was the actual length of framerail added?
1952 M37cdn
camoyj7
Re: Project M37a4
Post by camoyj7 »
Ended up being 36 1/2" added to frame.
m37 39.jpg (65.82 KiB) Viewed 20509 times
m37 40.jpg (70.75 KiB) Viewed 20509 times
