Project M37a4
Project M37a4
I'm calling it a M37a4. It going to be a 61 M37B1 made into a four door, full size bed, with a 3.9 Cummins 4bt, 5spd, Dana 60 axles, four wheel disc brakes, hmmwv 24 bolt wheels w/37" Goodyears. All late model military stuff led lighting, seats, hmmwv gun turret, ect.
- m37 11.jpg (66.89 KiB) Viewed 17311 times
- m37 10.jpg (85.6 KiB) Viewed 17311 times
- m37 9.jpg (85.13 KiB) Viewed 17311 times
Re: Project M37a4
More
- m37 14.jpg (55.22 KiB) Viewed 17310 times
- m37 13.jpg (69.67 KiB) Viewed 17310 times
- m37 12.jpg (69.96 KiB) Viewed 17310 times
Re: Project M37a4
More
- m37 17.jpg (69.77 KiB) Viewed 17310 times
- m37 16.jpg (71.38 KiB) Viewed 17310 times
- m37 15.jpg (72.29 KiB) Viewed 17310 times
Re: Project M37a4
This will be my second crew cab conversion. I did a M35a2 a few years ago in my small garage.
- SSGR12q.jpg (81.07 KiB) Viewed 17310 times
- 2.jpg (90.38 KiB) Viewed 17310 times
- 1.jpg (78.82 KiB) Viewed 17310 times
- W_A_Watson_II
Re: Project M37a4
Should be a cool build, looking forward to the results,
Re: Project M37a4
I've often thought it would be fun doing a 'what-if' Command Car version of the M37.
Monkey Man
- Site Admin
Re: Project M37a4
Your M37 build is truly impressive....
MM
MM
Trained Monkey on Guard
dodgem37@netspace.net.au
Master Yota
- MSGT
Re: Project M37a4
I'm impressed that you managed the M35 in that garage.
I've wondered about a 4 door M37, and I'm subscribed to your build. Keep the pictures coming!
Ray
1953 CDN. M37
1954 CDN. M152
1953 CDN. M37
1954 CDN. M152
Monkey Man
- Site Admin
Re: Project M37a4
Your M37 will be awesome, I did however mean to say your M35 is Truly Impressive, I should put my brain into gear before typingMonkey Man wrote:Your M37 build is truly impressive....
MM
MM
Re: Project M37a4
Doing the M35a2 in that garage was a challenge. It's a 7 1/2 tall on the inside not much head room. Because how long it was I had to do the frame stretch out side.
- 6.jpg (100.66 KiB) Viewed 17253 times
- 5.jpg (65.67 KiB) Viewed 17253 times
- 4.jpg (89.59 KiB) Viewed 17253 times
Re: Project M37a4
I just picked some new seats for the M37.
- seat.jpg (64.98 KiB) Viewed 17181 times
- W_A_Watson_II
Re: Project M37a4
WOW, those are nice. What brand?
Re: Project M37a4
They are MRAP Military GSS COBRA seats.
Re: Project M37a4
Great seats!!
I've been looking at them for a while, they are mine/ied blast protection, (read heavy) so shipping to Argentina would be expensive indeed. That kept me away.
Juan Castro
Buenos Aires
Argentina
Buenos Aires
Argentina
Re: Project M37a4
Made some progress today got to cut and stretched the frame. I'm still not sure what the total wheel base is going to be yet. I made the frame extensions a lot longer than I'm going to need so I can shorten them once the crew cab is built. For right now the rear rails are just bolted together. I'll have to notch the new cross member for the driveshaft once I can see where the NP205 will sit.
- m37 25.jpg (66.09 KiB) Viewed 17097 times
- m37 22.jpg (71.8 KiB) Viewed 17097 times
- m37 21.jpg (62.46 KiB) Viewed 17097 times
