Project M37a4
camoyj7
Project M37a4
Post by camoyj7 »
I'm calling it a M37a4. It going to be a 61 M37B1 made into a four door, full size bed, with a 3.9 Cummins 4bt, 5spd, Dana 60 axles, four wheel disc brakes, hmmwv 24 bolt wheels w/37" Goodyears. All late model military stuff led lighting, seats, hmmwv gun turret, ect.
m37 11.jpg (66.89 KiB) Viewed 16925 times
m37 10.jpg (85.6 KiB) Viewed 16925 times
m37 9.jpg (85.13 KiB) Viewed 16925 times
camoyj7
Re: Project M37a4
Post by camoyj7 »
More
m37 14.jpg (55.22 KiB) Viewed 16924 times
m37 13.jpg (69.67 KiB) Viewed 16924 times
m37 12.jpg (69.96 KiB) Viewed 16924 times
camoyj7
Re: Project M37a4
Post by camoyj7 »
More
m37 17.jpg (69.77 KiB) Viewed 16924 times
m37 16.jpg (71.38 KiB) Viewed 16924 times
m37 15.jpg (72.29 KiB) Viewed 16924 times
camoyj7
Re: Project M37a4
Post by camoyj7 »
This will be my second crew cab conversion. I did a M35a2 a few years ago in my small garage.
W_A_Watson_II
Re: Project M37a4
Post by W_A_Watson_II »
Should be a cool build, looking forward to the results,
Will
1946 Dodge Power Wagon
My 1953 Dodge M37 WEB Site
JimC
Re: Project M37a4
Post by JimC »
I've often thought it would be fun doing a 'what-if' Command Car version of the M37.
Monkey Man
Site Admin
Site Admin
Re: Project M37a4
Post by Monkey Man »
Your M37 build is truly impressive....
MM
Trained Monkey on Guard
dodgem37@netspace.net.au
Master Yota
Re: Project M37a4
Post by Master Yota »
I'm impressed that you managed the M35 in that garage. :shock:
I've wondered about a 4 door M37, and I'm subscribed to your build. Keep the pictures coming!
Ray
1953 CDN. M37
1954 CDN. M152
Monkey Man
Site Admin
Site Admin
Re: Project M37a4
Monkey Man wrote:Your M37 build is truly impressive....
MM
Your M37 will be awesome, I did however mean to say your M35 is Truly Impressive, I should put my brain into gear before typing :roll:
MM
camoyj7
Re: Project M37a4
Post by camoyj7 »
Doing the M35a2 in that garage was a challenge. It's a 7 1/2 tall on the inside not much head room. Because how long it was I had to do the frame stretch out side.
camoyj7
Re: Project M37a4
Post by camoyj7 »
I just picked some new seats for the M37.
W_A_Watson_II
Re: Project M37a4
WOW, those are nice. What brand?
Will
camoyj7
Re: Project M37a4
Post by camoyj7 »
They are MRAP Military GSS COBRA seats.
Juan
Re: Project M37a4
Post by Juan »
Great seats!!
I've been looking at them for a while, they are mine/ied blast protection, (read heavy) so shipping to Argentina would be expensive indeed. That kept me away.
Juan Castro
Buenos Aires
Argentina
camoyj7
Re: Project M37a4
Post by camoyj7 »
Made some progress today got to cut and stretched the frame. I'm still not sure what the total wheel base is going to be yet. I made the frame extensions a lot longer than I'm going to need so I can shorten them once the crew cab is built. For right now the rear rails are just bolted together. I'll have to notch the new cross member for the driveshaft once I can see where the NP205 will sit.
m37 25.jpg (66.09 KiB) Viewed 16711 times
m37 22.jpg (71.8 KiB) Viewed 16711 times
m37 21.jpg (62.46 KiB) Viewed 16711 times
