PICTURES!! Front Clip teardown...
Re: TURNING BRAKE DRUMS...
I can't wait to see how the over sized brake linings work out in regards to adjustments.
Check your PMs to see how I got the measurements
Gary,
I did read my PM about the sizes, that's why I'm patiently waiting for the next step in this project.
Well we're getting there Bert-I don't mind being the pace setter on this task-I've followed a number of posts over the years that have been a tremendous help.
I figure that if I've measured everything correctly, once I install these I should have plenty of room to adjust them out as they wear and won't have to do this job again.
Since I keep a journal on all the M37 work, parts, etc., eventually I'll hand everything off to the next owner who will have all the details as needed.
PICTURES!! Got the oversized brake shoes...
Thanks to Charles at M-Series for the special order! Now I need to prep for the install, meaning find the time and a day with temps above freezing so I can get them installed and adjusted.
More to follow,
More to follow,
Re: Got the oversized brake shoes...
Thats good news Gary, I would like to see how this all comes together.
Thanks Bert-I'll post updates and pix once I get moving....
Bert,
PM sent.
PM sent.
Re: PICTURES!! Got the oversized brake shoes...
3 pictures to show-ready for install.
- ready for install.JPG (13.43 KiB) Viewed 3175 times
- shoe leading edge cut.JPG (20.61 KiB) Viewed 3175 times
- old sshoe vs new.JPG (21.91 KiB) Viewed 3175 times
Hi Gary,
Now that I see the pictures of the brake linings, I understand why you needed to trim them. Thanks for posting them. Please keep us posted on how the adjustment process goes with the new shoes.
Sure will, Bert-PM sent.
