Patching Bed
Rdinatal
Patching Bed
Post by Rdinatal »
The M37 bed previously had something bolted down (hose reel?). Over time that area has rusted through so there are now four 4"x4" patches of holes surrounding the original 1/2" bolt hole. The rest of the bed is in VG condition.
Where would I find some bed material to cut out patches for repair? Plan to cut/weld.
Re: Patching Bed
Rdinatal,
Check with Midwest Military. I think they're making bits for floors.
Re: Patching Bed
I could swear I saw a post on here at some point by someone who had figured out a way to match the bends in the bed metal to make pieces for patches. He was just using common tools and scraps of metal for the form. I just can't recall when or where I saw it, or who posted it.
Blue Chips
Re: Patching Bed
Post by Blue Chips »
Rdinatal wrote: Sun Aug 18, 2024 3:38 am The M37 bed previously had something bolted down (hose reel?). Over time that area has rusted through so there are now four 4"x4" patches of holes surrounding the original 1/2" bolt hole. The rest of the bed is in VG condition.
Any good sheet metal shop should be able to match the bends in the bed floor corrugations without any trouble if they have a small sample to work with. If you had a sheet metal bending brake you could do it yourself. If you're going to cut out the rusted areas, maybe you could include just enough solid metal to give the shop a sample.
Rdinatal
Re: Patching Bed
Post by Rdinatal »
All good replies, thank you.
Checking with Midwest first. Second will be local shops.
Re: Patching Bed
Or, get a fuel sender access floor panel and use it.
