Crush Washers for F&R Axles
Rdinatal
Post by Rdinatal »
What is the consensus on oil drain crush washers? The ones I have are about worn out. No 'crush left to them.
Any substitutes?
Re: Crush Washers for F&R Axles, Transmission, Transfer Case
Mil-spec copper/asbestos (or whatever the modern substitute is for asbestos...) MS35769-18 (7/8" ID).
Available from places like skygeek.com, etc.
Skygeek MS35769-18.jpg (237.29 KiB) Viewed 5099 times
get rubber gasket metal sealing washers, they come in all sorts of sizes, I use them here and there on my truck. Pegasus Auto Racing. Hal
My Ace Hardware has them. Any auto supply will have them. I anneal them at each oil change until they are too deformed. Then use a new one.
Rdinatal
Post by Rdinatal »
I tried O Rings. Even though they work the trust isn't there when it comes to holding. The rubber shifts/compresses too easily.
Elwood's reference to those on skygeek.com... Those definitely are 'special'.
I found these and they work great. Able to tighten and stay, malable enough to seal great, and affordable.
M22 Flat Washer Copper Sealing... https://www.amazon.com/dp/B09H4GDD14?re ... b_ap_share
The metric washers fit OK?
Rdinatal
Post by Rdinatal »
John Mc wrote: Thu Oct 12, 2023 9:07 am The metric washers fit OK?
That size fits perfectly.
