M37 Points & condenser
1963M37B1
Post by 1963M37B1 »
2016 12-11a The M37.jpg (176.78 KiB) Viewed 2522 times
Back in 2007 I bought this M37 and now that I have retired I am trying to get it running. The distributor has no points or condenser in it. What does one buy at the local parts store for a 1963 M37? Isn't there a parts conversion list somewhere for plugs, points, condenser, etc? Can't seem to find it with the search feature?
Looks like I need to post a smaller picture somehow.
1963M37B1
Re: M37 Points & condenser
Post by 1963M37B1 »
Was searching in the wrong forum, found Napa Echlin CS725A for points and AL869 for condenser in the Technical forum. :oops:
Tom P
Post by Tom P »
This is what I have on file all Standard Motor Parts (SMP)
Don't know how current the numbers are.
Points SMP# AL-4556XP GAP=.020
Condenser SMP# AL-118X
Rotor SMP# AL-150
Spark Plugs Autolite# 295
Coil, Cap, Wires from MV part suppliers only.
Tom
"47" WDX WW
"52" M37 WW
"54" Willys M38A1
"65" M35A1 WW
To Many Others
Auto-lite plug # 295 listed above is not the waterproof original type plug for M37, and is not compatible with mil spec waterproof cables. 295 is a civilian plug that would be used in a situation where a system is being converted to a 12-volt civilian set up, and waterproof components are not being used.
isaac_alaska
Post by isaac_alaska »
good chance to install a Pertronix :)
Isaac
Fairbanks, AK
Civilian WM300 on DC3 tires
'52 M37 on 11x16 Michelin
Photo Gallery
DJ
Post by DJ »
Welcome to retirement, now you will wonder how you had time to work.
Stovebolt
Post by Stovebolt »
FWIW ... Ditch the points! I did the Pertronix upgrade in my M-37 and I couldn't be happier with it. Very easy to do and you don't have the hassle of the points, condenser blah blah blah.
I did it on a spur of the moment decision and my test drive was a 250-mile jaunt down the outer banks of North Carolina with zero problems (well, other than vapor lock but that wasn't an ignition issue ...)
Just sayin'
Congrats on the retirement -- hope to join you soon!
1963 Dodge M-37B-1 W/W -- "Requisitioned" from the Army ...
"Last to Know, First to Go."
