Transmission boot
Re: Transmission boot
If it has petrified, you will need to destroy it and buy a new one.
If it hasn't, you should be able to gently pry it out. You could also remove the tunnel cover and push it thru from the bottom side.
I bumped mine when I pulled my engine and tranny
and it shattered
and it shattered
Thanks,TRAVIS
1952 M37 FARM TRUCK
1941 WC RATROD
1952 M37 FARM TRUCK
1941 WC RATROD
these things came with a transmission boot? o.O
Isaac
Fairbanks, AK
Civilian WM300 on DC3 tires
'52 M37 on 11x16 Michelin
Photo Gallery
Fairbanks, AK
Photo Gallery
- PFC
I just replaced mine after a Transmission Rebuild.
I have a NP 88950 so I purchased the miniature "Top Hat" from Vintage Power Wagons.
It fits nicely since it's actually pliable.
My Floor gasket crumbled around the Tower Base.
I bought one of those too from Vintage, although I suspect that there must be after market ones out there.
I just never stopped by a Tranny shop to ask..
It sure looks good once your plate, tower and gaskets are all painted & in place.
We even fixed the Transfer Lever "weather" gasket on the floor plate using a Rubber Stair Runner from home depot.
Cut it using the pieces from what was left of the original.
Looks like new.
Looks like new.
