Transmission boot
rcamacho
Transmission boot
Post by rcamacho »
Anyone know how to remove the transmission boot from the trans tunnel?
'51 M37
Re: Transmission boot
If it has petrified, you will need to destroy it and buy a new one.
If it hasn't, you should be able to gently pry it out. You could also remove the tunnel cover and push it thru from the bottom side.
52PLOWERWAGON
Post by 52PLOWERWAGON »
I bumped mine when I pulled my engine and tranny
and it shattered :shock:
Thanks,TRAVIS
1952 M37 FARM TRUCK
1941 WC RATROD
isaac_alaska
Post by isaac_alaska »
these things came with a transmission boot? o.O
Isaac
Fairbanks, AK
Civilian WM300 on DC3 tires
'52 M37 on 11x16 Michelin
Photo Gallery
LegionPiper
Post by LegionPiper »
I just replaced mine after a Transmission Rebuild.
I have a NP 88950 so I purchased the miniature "Top Hat" from Vintage Power Wagons.
It fits nicely since it's actually pliable.
My Floor gasket crumbled around the Tower Base.
I bought one of those too from Vintage, although I suspect that there must be after market ones out there.
I just never stopped by a Tranny shop to ask..
It sure looks good once your plate, tower and gaskets are all painted & in place.
We even fixed the Transfer Lever "weather" gasket on the floor plate using a Rubber Stair Runner from home depot.
Cut it using the pieces from what was left of the original.
Looks like new.
