Combat Wheels - replacement parts (studs/outer rings)
rcamacho
Post by rcamacho »
I managed to pick up 6 combat wheels. Most are in rough shape so I expect only a few will be salvageable after disassembly and blasting.
Does anyone know what size the studs are and if anyone can supply new studs and potentially outer rings?
'51 M37
rcamacho
Re: Combat Wheels - replacement parts (studs/outer rings)
Post by rcamacho »
Found on VPW
'51 M37
point
Post by point »
I came on site to ask the very same question tonight. I need studs. What or where is VPW? Pardon my ignorance.
rcamacho
Post by rcamacho »
http://www.vintagepowerwagons.com/pdf/p ... wheels.pdf
Look for combat wheel studs on this page.
[quote="point"]I came on site to ask the very same question tonight. I need studs. What or where is VPW? Pardon my ignorance.[/quote
'51 M37
point
Post by point »
Thanks. That was quick
John B @ Midwest Military has them also, I bought my new outer ring studs and nuts from. Not sure if he has the outer rings.
rcamacho
Post by rcamacho »
Drat, 4/6 wheels are structurally corroded beyond repair. outer rings and inner rim are rusted all the way through. It's unfortunate they were left unprotected in the elements for so long.
'51 M37
rcamacho wrote:Drat, 4/6 wheels are structurally corroded beyond repair. outer rings and inner rim are rusted all the way through. It's unfortunate they were left unprotected in the elements for so long.
That is too bad, hope they were not too $$?
