I managed to pick up 6 combat wheels. Most are in rough shape so I expect only a few will be salvageable after disassembly and blasting.
Does anyone know what size the studs are and if anyone can supply new studs and potentially outer rings?
Combat Wheels - replacement parts (studs/outer rings)
Re: Combat Wheels - replacement parts (studs/outer rings)
I came on site to ask the very same question tonight. I need studs. What or where is VPW? Pardon my ignorance.
http://www.vintagepowerwagons.com/pdf/p ... wheels.pdf
Look for combat wheel studs on this page.
[quote="point"]I came on site to ask the very same question tonight. I need studs. What or where is VPW? Pardon my ignorance.[/quote
'51 M37
Thanks. That was quick
John B @ Midwest Military has them also, I bought my new outer ring studs and nuts from. Not sure if he has the outer rings.
Drat, 4/6 wheels are structurally corroded beyond repair. outer rings and inner rim are rusted all the way through. It's unfortunate they were left unprotected in the elements for so long.
'51 M37
That is too bad, hope they were not too $$?rcamacho wrote:Drat, 4/6 wheels are structurally corroded beyond repair. outer rings and inner rim are rusted all the way through. It's unfortunate they were left unprotected in the elements for so long.
