Ok I was hooking up my wiring and seem to be lacking a wire
bubba_got_you
Post by bubba_got_you »
Ok I was hooking up my wiring and seem to be lacking a wire that goes to the distributor. Is this a separate wire? Or how does the distributor get electric?
Re: Ok I was hooking up my wiring and seem to be lacking a w
bubba_got_you wrote:Ok I was hooking up my wiring and seem to be lacking a wire that goes to the distributor. Is this a separate wire? Or how does the distributor get electric?
Assuming you have the original distributor, there is only 1 wire that feeds power to the unit. #12 coming from the ignition switch. On the early trucks that have the firewall mounted radio suppression filter, it comes from the switch to the filter, then proceeds from there to the distributor. Only the 1 wire either way though.
Rick C
Post by Rick C »
Not sure why, but the harness I put in my M43 had the distributor lead on the passenger side of the truck. Had to run a wire over to the distributor.
Rick C
Rick C wrote:Not sure why, but the harness I put in my M43 had the distributor lead on the passenger side of the truck. Had to run a wire over to the distributor.
Rick C
The reason is that harness was for the early trucks that had the filter box on the firewall. The later harness has #12 wire coming directly from the ign switch to the distributor, #12 on the later style harness exits the fire wall on the drivers side.
Rick C
Post by Rick C »
Thanks Charles. It was a repro harness and could never figure why they would put the wire all the way over there LOL
Rick C
