Page 9 of 12
Re: Grandpa’s M37
Posted: Mon Apr 18, 2022 8:33 pm
Start there. Also check to ensure no burrs on the inner cable. Also check to ensure the ends are secure on the cable and not loose.
Re: Grandpa’s M37
Posted: Sat Apr 30, 2022 9:42 am
by greeno
- A28467D5-684D-4647-BA6B-1F4B2AA80694.jpeg (82.53 KiB) Viewed 9282 times
Re: Grandpa’s M37
Posted: Tue May 17, 2022 6:45 am
by greeno
Cal_Gary wrote: ↑Mon Apr 18, 2022 8:33 pm
That worked well! The speedo flutters a bit +_ 2 mph but not like it was.
Re: Grandpa’s M37
Posted: Thu May 19, 2022 8:03 am
by Argie1978
+/- 2 mph is nothing for this trucks. Congrats.
Re: Grandpa’s M37
Posted: Wed May 25, 2022 5:07 pm
by greeno
This works for now, but has anyone figured out the right tips you can put on civy wires?
- D9DEDA9F-66E7-4F97-88EE-B13ECD1A8597.jpeg (123.7 KiB) Viewed 9160 times
Re: Grandpa’s M37
Posted: Mon May 30, 2022 7:19 am
by greeno
Can you change the shifter shaft seals with the transfer case in the truck? That’s my biggest leak after the front pinion seal (why didn’t I change it beforehand?!?!?!)
Re: Grandpa’s M37
Posted: Mon May 30, 2022 10:50 pm
by PoW
It can be done, but it is a lot of jockeying tools around to remove them.
I drill 2 small holes along the front edge of the seal, 180deg apart.
Use a couple #8 or so sheet metal screws to pull the seal out with a small crowbar.
Then use a drill with a wire brush or some of that abrasive ribbon for soldering pipe to remove any rust/rough spots on the fully extended shafts .
Take a 6"piece of pipe that will slip over the shaft and drive the new seals in with a small hammer, using a bit of sealant on the seal rims first.
Done.
Keep in mind, synthetic gear oil will let the transfer run quieter & cooler, but it will find the smallest space to leak more than regular gear oil.
Re: Grandpa’s M37
Posted: Sat Jun 04, 2022 1:31 pm
by greeno
Finished painting the bed with my secret recipe.
- 21F6FBC7-1AF0-4C00-908B-307FAF6C2F22.jpeg (79.86 KiB) Viewed 9105 times
Re: Grandpa’s M37
Posted: Sat Jun 04, 2022 7:15 pm
by m-37Bruce
Outstanding, looks great!
Re: Grandpa’s M37
Posted: Sun Jun 05, 2022 4:52 pm
by RCrombie
Sigh.... I wish my wheel arches were that clean
Re: Grandpa’s M37
Posted: Sun Jun 05, 2022 6:47 pm
by greeno
Thanks. There is a ton of hammering in those. I think I tore it down just in time to stop the rust worms.
Re: Grandpa’s M37
Posted: Wed Jun 08, 2022 7:33 am
by Argie1978
Looks like it's coming out of the producing plant right now!
Re: Grandpa’s M37
Posted: Sun Jun 12, 2022 4:48 am
by greeno
Took a 6 mile trip to the gas station this am. First trip in traffic. Ran fine. Didn’t make too many people mad by my slowness. Pulled the #1 plug looks ok.
- 0985AADF-6865-4514-B433-9DCD51F79415.jpeg (121.3 KiB) Viewed 9046 times
Re: Grandpa’s M37
Posted: Sun Jun 12, 2022 2:02 pm
by NAM VET
"reading" plugs is somewhat of a lost art. A few minutes of idle can really soot up a plug, One thing we can look for is a very overheated plug, or broken ceramic or bent/melted electrodes. When I pull my plugs for any reason, I use mew copper compression washers, I get them in various thickness from Jegs, used for "indexing" spark plugs. Plus anti seize and use a good torque wrench. Important to use the proper heat range too. I think "heat range" actually refers to the ceramic insulator, a bit longer to project more into the combustion chamber to burn off deposits better, ie, a hot plug, and for a cold plug, a shorter insulator.
hal
Re: Grandpa’s M37
Posted: Sat Jul 02, 2022 6:19 pm
by greeno
Hood is on!
- 14B47394-F8C9-4A8E-B1FC-3C2FA77C447A.jpeg (100.56 KiB) Viewed 9003 times
