Grandpa’s M37
Re: Grandpa’s M37
Start there. Also check to ensure no burrs on the inner cable. Also check to ensure the ends are secure on the cable and not loose.
greeno
Re: Grandpa’s M37
Post by greeno »
M37
YEAR: 1954
greeno
Re: Grandpa’s M37
Post by greeno »
Cal_Gary wrote: Mon Apr 18, 2022 8:33 pm Start there. Also check to ensure no burrs on the inner cable. Also check to ensure the ends are secure on the cable and not loose.
That worked well! The speedo flutters a bit +_ 2 mph but not like it was.
M37
YEAR: 1954
Argie1978
Re: Grandpa’s M37
Post by Argie1978 »
+/- 2 mph is nothing for this trucks. Congrats. :)
Sebastian
greeno
Re: Grandpa’s M37
Post by greeno »
This works for now, but has anyone figured out the right tips you can put on civy wires?
M37
YEAR: 1954
greeno
Re: Grandpa’s M37
Post by greeno »
Can you change the shifter shaft seals with the transfer case in the truck? That’s my biggest leak after the front pinion seal (why didn’t I change it beforehand?!?!?!)
M37
YEAR: 1954
Re: Grandpa’s M37
It can be done, but it is a lot of jockeying tools around to remove them.
I drill 2 small holes along the front edge of the seal, 180deg apart.
Use a couple #8 or so sheet metal screws to pull the seal out with a small crowbar.
Then use a drill with a wire brush or some of that abrasive ribbon for soldering pipe to remove any rust/rough spots on the fully extended shafts .
Take a 6"piece of pipe that will slip over the shaft and drive the new seals in with a small hammer, using a bit of sealant on the seal rims first.
Done.
Keep in mind, synthetic gear oil will let the transfer run quieter & cooler, but it will find the smallest space to leak more than regular gear oil.
greeno
Re: Grandpa’s M37
Post by greeno »
Finished painting the bed with my secret recipe.
M37
YEAR: 1954
Re: Grandpa’s M37
Outstanding, looks great!
RCrombie
Re: Grandpa’s M37
Post by RCrombie »
Sigh.... I wish my wheel arches were that clean
greeno
Re: Grandpa’s M37
Post by greeno »
Thanks. There is a ton of hammering in those. I think I tore it down just in time to stop the rust worms.
M37
YEAR: 1954
Argie1978
Re: Grandpa’s M37
Post by Argie1978 »
Looks like it's coming out of the producing plant right now! :shock:
Sebastian
greeno
Re: Grandpa’s M37
Post by greeno »
Took a 6 mile trip to the gas station this am. First trip in traffic. Ran fine. Didn’t make too many people mad by my slowness. Pulled the #1 plug looks ok.
M37
YEAR: 1954
Re: Grandpa’s M37
"reading" plugs is somewhat of a lost art. A few minutes of idle can really soot up a plug, One thing we can look for is a very overheated plug, or broken ceramic or bent/melted electrodes. When I pull my plugs for any reason, I use mew copper compression washers, I get them in various thickness from Jegs, used for "indexing" spark plugs. Plus anti seize and use a good torque wrench. Important to use the proper heat range too. I think "heat range" actually refers to the ceramic insulator, a bit longer to project more into the combustion chamber to burn off deposits better, ie, a hot plug, and for a cold plug, a shorter insulator.
hal
greeno
Re: Grandpa’s M37
Post by greeno »
Hood is on!
M37
YEAR: 1954
