Need new tires very soon
slk
Post by slk »
Hey guys are the standard tires that came on the M37’s suitable for ice and snow. The 9.00x16 with military tread. I have never driven my truck in the winter up here in MN but to me the tread does not look to favorable for slick roads.
Steve
JimC
Re: Need new tires very soon
Post by JimC »
They do OK after you slide off into the ditch. :?
slk
Post by slk »
Exactly what i was thinking.
You're in for some excitement if you drive the NDTs in snow, and especially on ice.
If you're running stock rims, the STA Superlug Mud & Snow 9.00x16 seems to be the default choice for non-NDT tires, at least for ones that are currently available. I bought a set to put on my spare rims, seeing as how we get around 140" of snow each winter.
slk
Post by slk »
A big issue now seams to be finding a shop that will mount them. Split rims seam to be a taboo with most places
slk
Post by slk »
I have since found out I may be calling the rims the wrong thing. I have been corrected. I guess the right term is split rings.
The correct term is Goodyear Safety Lock Ring wheel.
NDTs are fine in the snow only if you're running chains.
