Grandpa’s M37
greeno
Re: Grandpa’s M37
Post by greeno »
Pretty detailed….but very, very small.
M37
YEAR: 1954
UZIS9MM
Re: Grandpa’s M37
Post by UZIS9MM »
You're going to need some hella small tools to work on that beast!
greeno
Re: Grandpa’s M37
Post by greeno »
Ish. Not for me!
M37
YEAR: 1954
greeno
Re: Grandpa’s M37
Post by greeno »
Finally got a bunch of parts back from the blasters. Another trip to MWM is in order too. But I did drive it up and down the street on Sunday waving to the neighbors!
M37
YEAR: 1954
Re: Grandpa’s M37
Looking GOOD!
Re: Grandpa’s M37
Awesome work Greeno!
greeno
Re: Grandpa’s M37
Post by greeno »
So, I, uh, was cleaning up the shop and found the bench bleeding instructions for the mc….which I forgot to do!
Tear it out and bench bleed? Everything is hooked up.
M37
YEAR: 1954
Re: Grandpa’s M37
I never bench bleed a MC.
Get a pressure bleeder and do it in the truck.
You only have to do it once that way, and you can do it without any helper.
Re: Grandpa’s M37
I made this up to easily pressurize my MC, and bleed my brakes by myself. Be sure to turn off the vent valve, or you will pump brake fluid out onto the garage floor. Bought from Jegs or Summit a half inch NPT fitting and then from same a smaller NPT with a nipple, and a Motive pressure bleeder which I have used before on other cars. Let me try to post a pic.... Hal.
Image[/img]
Re: Grandpa’s M37
ok try again.
Re: Grandpa’s M37
Is it hand pumped Hal?
Re: Grandpa’s M37
yeah, a tank with with a pump handle, with a pressure gage, and a plastic hose you can connect to whatever fitting you want. Takes a little planning to get what you need, but works slick as a whistle. Jegs or Summit has what you need. Hal
Re: Grandpa’s M37
Same as Hal-Motive bleeder with a fabbed MC plug.
greeno
Re: Grandpa’s M37
Post by greeno »
Thanks guys. Wasn’t sure if there was any magic in bleeding on the bench. Doesn’t sound like it, just might take a little more time to properly bleed the system.
M37
YEAR: 1954
greeno
Re: Grandpa’s M37
Post by greeno »
Speedo bounces a lot. Lube the inner cable?
https://youtu.be/r3K840r1G0Y
M37
YEAR: 1954
