1954 M37 rebuild thread
Re: 1954 M37 rebuild thread
DSC01666 (Small).JPG (117.75 KiB) Viewed 10112 times
Some Oak painted. 2 coats of Thompsons water seal and 3 coats of OD.
DSC01667 (Small).JPG (115.05 KiB) Viewed 10112 times
DSC01671 (Small).JPG (127.18 KiB) Viewed 10112 times
DSC01670 (Small).JPG (112.23 KiB) Viewed 10112 times
Some dash pics.
DSC01668 (Small).JPG (109.61 KiB) Viewed 10112 times
one more.
Outstanding!
greeno
Post by greeno »
Dangggggg!!!! That’s fantastic work, you should be very proud.
M37
YEAR: 1954
DSC01686 (Small).JPG (104.89 KiB) Viewed 10065 times
DSC01685 (Small).JPG (104.7 KiB) Viewed 10065 times
DSC01684 (Small).JPG (113.81 KiB) Viewed 10065 times
Putting in my new axle shafts.
DSC01687 (Small).JPG (123.02 KiB) Viewed 10065 times
DSC01688 (Small).JPG (118.03 KiB) Viewed 10065 times
DSC01689 (Small).JPG (101.98 KiB) Viewed 10065 times
More pics. The hub is steel, with a cap of aluminum. The shaft has a spring clip in the notch at the hub end.
greeno
Post by greeno »
Those 7/16" washers on the dash...are they split lock washers or something else? I'm still figuring out what to do now that the periphery washers are unobtainium.
M37
YEAR: 1954
greeno wrote:Those 7/16" washers on the dash...are they split lock washers or something else? I'm still figuring out what to do now that the periphery washers are unobtainium.
Those are thick grade 8 flat washers. I didn't use split lockwashers, I relied on locknuts and locktite where necessary. I used a few mars washers (what we called them years ago- don't know why) on the smaller bolts(like on the door).
DSC01690 (Small).JPG (106.96 KiB) Viewed 10043 times
I also used these in places.
DSC01693 (Small).JPG (154.61 KiB) Viewed 9903 times
DSC01692 (Small).JPG (174.53 KiB) Viewed 9903 times
DSC01691 (Small).JPG (179.18 KiB) Viewed 9903 times
It is alive! drove it a couple of miles, nothing fell off- or drained out! everything seems well so far, having some TC shifter issues-probably adjustment issues.
DSC01695 (Small).JPG (160.35 KiB) Viewed 9903 times
DSC01694 (Small).JPG (158.68 KiB) Viewed 9903 times
More pics.
Looking great!
I'm curious: was there a problem with your old axles, or were you just worried about them for the future?
John Mc wrote:Looking great!
with the 375 HP hemi I figured that I maybe needed something stronger, having heard so many stories of the oem ones breaking- with the stock driveline. Granted, I have heard of the people who have never had a problem. For me it was just good insurance. The axles I removed were perfectly fine.
Makes sense. I missed the part about the new engine.
