greeno wrote:I’d love to know how to get the nut on this screw after you get the sides on!
right now it is there just to keep everything straight. I assume that you can get to it from the bottom with an extension (been a while since I tore it apart).
DSC01589 (Small).JPG (116.44 KiB) Viewed 3915 times
DSC01588 (Small).JPG (109.38 KiB) Viewed 3915 times
got one side done, have you ever seen so many holes? It had/has two antenna mounts (it is an M42). Mounts will go back on- I'll have to see what else I can install- with all of my predrilled attaching spots.
I have pretty much figured out that the fuel filler tube needs to be attached to the side before you install the side, as I cannot get it in now. Luckily the side is only sitting there (test fit) to find out these kind of problems. everything else seems to fit fine.
DSC01600 (Small).JPG (127.06 KiB) Viewed 3832 times
DSC01599 (Small).JPG (123.12 KiB) Viewed 3832 times
DSC01598 (Small).JPG (125.64 KiB) Viewed 3832 times
A little paint and it will be like new!! This is after several hours of pounding trying to get it straight, worst part on the whole truck. I wish these things weren't so expensive, would like a better one. Took me several years to find this one (at a price I would pay). My truck didn't have a tailgate when I bought it, It is a mess.
