Hello Guys, I did searches but could not find what I need.
I will be replacing them as well as the windows L shaped.
The ones in the doors seems to be not original do you have a picture with the profile? you will see it from above with door opened.
this is what I have the L shaped in milimeters with max allowed dimention and the alctual measured, then the ones mounted today to the doors
when they control both houses. http://www.militarystencils.com
Midwest Military has the correct seals for the M37 in stock. May not be on the website, but we have them. We have 90% of all weatherstrips needed for the truck in total.
John
My problem is that I will not be travellign to the US and importing things its kind of difficult...
So I wwanted to see the original pattern in order to compare what I have here in a local store
Mine is dry and fragile but I don't know if it is or not the original. Seems to be just an "L" pattern the one sealing the window, and the rest of the door seals (if thy trully existed) definetelly are no original. They are glued to the door
Okay, here’s what’s around the window on the truck. All the rest of the rubber around the door appears to have disintegrated, so I guess I’ll be adding that to the to do list...
Let me know if this helps. I can also get measurements if you need them, I just didn’t have time to today.
