Doors weathersrips
vit16
Doors weathersrips
Post by vit16 »
Hello Guys, I did searches but could not find what I need.
I will be replacing them as well as the windows L shaped.
The ones in the doors seems to be not original do you have a picture with the profile? you will see it from above with door opened.
this is what I have the L shaped in milimeters with max allowed dimention and the alctual measured, then the ones mounted today to the doors
Imagecool restaurants in wilmington nc
milstencil
Re: Doors weathersrips
Post by milstencil »
vit16
Post by vit16 »
Thank you!
this is the correct seal?
JBizal
Post by JBizal »
Midwest Military has the correct seals for the M37 in stock. May not be on the website, but we have them. We have 90% of all weatherstrips needed for the truck in total.
John
vit16
Post by vit16 »
Thanks!
the previous owner installed something that its not original, do you have the pattern? take a look at my drawing, seems to be too new.
vit16
Post by vit16 »
My problem is that I will not be travellign to the US and importing things its kind of difficult...
So I wwanted to see the original pattern in order to compare what I have here in a local store
Vit, please add your location to your profile so we can better assist based on your location-thanks!
vit16
Post by vit16 »
Profile updated :)
Thanks Vit!
vit16
Post by vit16 »
Guys can anyone take a close picture to the door seal?
RCrombie
Post by RCrombie »
I’ll take a look at what’s on my truck, and post a picture if I can. A lot of it is pretty old and flattened so I don’t know if it will be of any use.
vit16
Post by vit16 »
Ok sounds good!!
Mine is dry and fragile but I don't know if it is or not the original. Seems to be just an "L" pattern the one sealing the window, and the rest of the door seals (if thy trully existed) definetelly are no original. They are glued to the door
RCrombie
Post by RCrombie »
Okay, here’s what’s around the window on the truck. All the rest of the rubber around the door appears to have disintegrated, so I guess I’ll be adding that to the to do list...
Let me know if this helps. I can also get measurements if you need them, I just didn’t have time to today.
vit16
Post by vit16 »
very nice! thank you RCrombie!!
it is very different from what I have. Mine it's just an "L" like what I draw in the first post.
again thank you!!
vit16
Post by vit16 »
forgot to ask you, how is that rubber holder or mounted? with screws? I have phillips screws so that didn't exist in those days hehe!!
