1954 M37 rebuild thread
Re: 1954 M37 rebuild thread
sturmtyger380 wrote:When you add this new piece of metal how are you going to deal with the reinforcing piece on the underside?
The patch kit came with a new bottom piece which is sandwiched between the fender and the frame. I know the original is spotwelded all over the place. I was thinking of just coating the thing with seam sealer and bolting it down tight.
The top edge is going to be bolted down with the headlight bracket bolts. I may put a small button head bolt (6/32) at the two bottom corners. Still working on it.
DSC01341 (Small).JPG (123.07 KiB) Viewed 2721 times
I hate welding!-- 'cause I don't know what I'm doing.
That doesn't look bad, 06. I recall an old post here where Charles at M-Series posted a "how to" for plugging the reinforcement plate underneath to keep water and debris out of the gap.
P.S. Here it is! http://www.g741.org/PHPBB/viewtopic.php ... l&start=15
DSC01344 (Small).JPG (116.12 KiB) Viewed 2704 times
all welded and starting the smooth out. I now know what warping is.
DSC01346 (Small).JPG (118.46 KiB) Viewed 2650 times
new instruments
Your cluster turned out really nice!
DSC01356 (Small).JPG (109.71 KiB) Viewed 2611 times
DSC01358 (Small).JPG (97.95 KiB) Viewed 2611 times
DSC01357 (Small).JPG (100.59 KiB) Viewed 2611 times
More pics of the fender.
these pieces I had to grind off the 4 rivits holding them on the fender so I could clean up the rust between them
DSC01359 (Small).JPG (117.47 KiB) Viewed 2611 times
DSC01361 (Small).JPG (148.46 KiB) Viewed 2608 times
DSC01360 (Small).JPG (156.08 KiB) Viewed 2608 times
green!
DSC00575 (Small).JPG (113.2 KiB) Viewed 2606 times
DSC00579 (Small).JPG (113.54 KiB) Viewed 2606 times
This is what the rear of the fender looked like before
Both of my front fenders were like that, I found a NOS driver's fender at VPW , it was worth it.
Managed to repair the passenger side.
Your work is outstanding, concours looking!!
I would never have even attempted a repair like yours turned out. First class work. NV
The good news is this fender is about done...the other side needs the same treatment!
Fantastic job 06! Thanks for the pictures too!
DSC01378 (Small).JPG (97.11 KiB) Viewed 2569 times
AH, I love the smell of canvas in the morning! My new cab top from MWM came in today.
