Wanted: Hot Water Heater Wiring.
Pat Gray
Post by Pat Gray »
Hello,
Looking for the wiring for the fender mounted heater for my M37. Any part or parts would be great. Thank you!! Pat
(I am in Washington State)
Re: Wanted: Hot Water Heater Wiring.
It is a spdt toggle switch, a resistor and some wire and connectors. Oh yeah, a circuit breaker. Easy to make if you can't find it.
This is the resistor.
Pat Gray
Post by Pat Gray »
Thank you, Is it a common part?
Thanks, Pat
Mouser or Digikey
