1954 M37 rebuild thread
Re: 1954 M37 rebuild thread
Project is looking good.
DSC01121 (Small).JPG (112.77 KiB) Viewed 6680 times
DSC01122 (Small).JPG (103.13 KiB) Viewed 6680 times
Does anyone know what attaches to these two captured nuts?
rickf
Post by rickf »
Front fender rear support?
RMS
Post by RMS »
supports the arctic heater fuel solenoid looking thing ?
They are 3/8" bolts, and there was nothing there when I took it apart. It probably has something to do with the arctic heater install like RMS said.
DSC01135 (Small).JPG (124.01 KiB) Viewed 6578 times
DSC01136 (Small).JPG (138.88 KiB) Viewed 6578 times
DSC01132 (Small).JPG (126.15 KiB) Viewed 6578 times
Decided on this tire. 385-70R16 Nitto. 37.7" tall.
rickf
Post by rickf »
That tire calls for a MINIMUM of a 9.5" wide rim. It looks like you have the stock 6" rim there. That would mean the bead is not even lose to being properly seated.
rickf wrote:That tire calls for a MINIMUM of a 9.5" wide rim. It looks like you have the stock 6" rim there. That would mean the bead is not even lose to being properly seated.
The wheel is 8.5" wide. It is a bit thin, but seems to work ok. I could not find any tires that were 38" tall and not really wide. The bead seats fine, as it is a tubeless wheel.
rickf
Post by rickf »
8.5 is not too bad but still an inch smaller than the minimum. They call for 9.5 to 13.5. The problem with tires that are too wide for the rime is that the sealing surface of the bead would normally sit flat on the rim at the correct width but when the rim is too narrow it bends the bead out and pivots the sealing surface away from the inner part of the sealing surface. You are probably not going to be driving this rig that many miles but when I had a 4x4 shop I would see this a lot and what would happen is the bead of the tire would eventually wear and fail because it was always moving. The indicator was usually the tire popping off the bead off road even with normal air pressure but a couple guys got into accidents when the tire popped off on turns on the road at speed. Big tire blowing off the bead in a turn at speed never ends well. One guy got away with it since the only damage was to his truck but the other guy was sued very heavily since he plowed into another car and severely injured a couple people. That was thirty years ago and he is still paying for it, He will never be able to buy a house or a new car. It is your vehicle and I don't preach. I just mention these things so you know what can happen. Not saying it will happen.
DSC01139 (Small).JPG (75.72 KiB) Viewed 6477 times
First coat of OD on the fix.
This bodywork stuff is not for the faint of heart--my first try.
Look back in this thread for before and during pics.
Darn, that turned out real nice!
murano3
Post by murano3 »
Great work!
Ben Connor
1952 M37 80026073
United Kingdom
http://www.afvn.co.uk
WeeksM37
Post by WeeksM37 »
The work looks amazing, you are doing an amazing job. How did you build your own wiring harness? What did you use for a layout? I assume the Hemi 5.7 had to be equipped with it's own sub harness and computer to control the engine. The remainder of truck would have to be sectioned off in order to support each component. Thank you, Mark
WeeksM37 wrote:The work looks amazing, you are doing an amazing job. How did you build your own wiring harness? What did you use for a layout? I assume the Hemi 5.7 had to be equipped with it's own sub harness and computer to control the engine. The remainder of truck would have to be sectioned off in order to support each component. Thank you, Mark
That was one of the big expenses for this job- a stand alone system with a complete new harness for the engine and transmission. Uses reprogrammed ECU, TCU, ABS modules (Squire Inc.). Everything else is pretty much a standard wiring system (Ron Francis).
Impressive work-thanks for the pictures!
