cab on its back?
cab on its back?
can you sit the cab on its back without bending anything? I have it off and would like to rest it on the back so I can get to the underside of the dash- rust removal and paint. The thing is quite heavy and I worry about bending something. Just wondering if anyone has set the cab on its back.
RMS
Re: cab on its back?
Post by RMS »
im going to say that it can. I have had 3 cabs on their backs and two now have tight doors. next time Im installing a brace to the fire wall
RMS
Post by RMS »
it can, 2 out of three cabs now have tight doors. next time Im installing a small brace to the fire wall
Agreed-no issues when I had my cab off-easier to clean the bottom, for sure.
You need to make a brace from dash to back of cab. There is plenty of support at the bottom of the cab but none at the top. You run the risk of bending the floor and making the doors tight.
just me wrote:You need to make a brace from dash to back of cab. There is plenty of support at the bottom of the cab but none at the top. You run the risk of bending the floor and making the doors tight.
If I still have the doors on is this necessary, or still a good idea?
I was actually more worried about the back skin, didn't think the floor was that weak.
Yep. You need to keep the door gap correct. It can just be some lumber sticks wedged in.
DSC01112 (Small).JPG (118.88 KiB) Viewed 1810 times
Used this method. Kept tension on the hoist.
DSC01117 (Small).JPG (125.87 KiB) Viewed 1810 times
cleaner, now to kill the rust.
What rust? I wish my cab looked that good... :)
