i can't take it. I'm going 12 volt...
Re: i can't take it. I'm going 12 volt...
Cal_Gary wrote:Carter has a plow on his-you might send him a PM....
My plow rig uses the winch and custom made frame and snatch block to raise and lower the plow, no electric or hydraulic needed.
http://www.g741.org/photogallery/main.p ... emId=14159
If I remember correctly, Carter's plow setup uses the mechanical LU-4 winch to raise and lower the blade, no 24v electronics involved.
ETA: Oops, I didn't see Carter's reply before I posted. :oops:
m37paul
Post by m37paul »
By his pictures, Carter uses the winch, not hydralics
LegionPiper
Post by LegionPiper »
Thanks guys !
Yeah, that's what I am missing, someone removed the Winch and PTO.
Likely why there's a 12 v Hydraulic power pack on the truck right now.
( Which had three batteries running it ... can you imagine ? )
Since the Charging system is working well, I want to put high draw devices at 24 V and then I'll run 12v lights and accessories via a Voltage Converter.
There's a lot of data on Hydraulic packs on Plow forums.
I'll hit them and figure out the best solution then report back.
I guess I'm no longer in the right thread, LOL...
I'll start a new one.
