F18hornetm
Re: 1953 M37
Post by F18hornetm »
Ha ha he will probably boot us off :shock: sometimes we all get off topic, but still nice to talk about things,
To get back on topic, I did prime the mirror brackets !! :D :D Hope to get back to work on it on sat
Re: 1953 M37
Here's one pic of my Passenger Side Mount.
Passenger Side Mirror Mount.jpg (69.93 KiB) Viewed 7867 times
Re: 1953 M37
Here's a wider shot.
Passenger Side Mirror Mount 2.jpg (99.73 KiB) Viewed 7867 times
F18hornetm
Re: 1953 M37
Oh that's nice arrangment. Thanks for the pics. Its completely different than mine where as mine mounts on the windshield pivot
Re: 1953 M37
If you are doing the gas can mount, this works, I have drawing with dimensions somewhere if your interested?
Jess
Re: 1953 M37
Post by Jess »
The easiest way to get a passenger side mirror mount is to copy the Canadian version. All CDN trucks had passenger side mirrors along with some other improvements on the original design. MWM has reproduced the mounting bracket if you don't want to make your own. I'll have to look for a pic to post or take another one when I get a moment. This topic has been covered here before...
F18hornetm
Re: 1953 M37
The ones I made copying the driver side I don't think will work with fuel can there. Of course mine is missing the fuel can mount and everything so I didn't think of it. Oh well, Ill still use what I made but if I install fuel can mount may make a different arm to clear it.
Pics of the Canadian version would be cool to. Guess ill have to dig up some pics on the fuel can mount. Although finding a good fuel can is pretty hard. I used to have a couple years ago but have no idea what I did with them.
Re: 1953 M37
I think Cabell made one that attached to the Jerry Can handles?
sturmtyger380
Re: 1953 M37
Post by sturmtyger380 »
I have thought about adding a mirror there but always figured the door or door glass would hit the mirror (if it is adjusted correct for you to see the passenger side blind spot) when you opened the door.
The other option I have seen is the bracket like I think the Canadians had where it was mounted off of the two bolts that hold the passenger fender side panel.
F18hornetm
Re: 1953 M37
Back to work on the old girl tomorrow. I think for now, since I have no fuel can mount, Ill mount the mirror on the windshield pivot like the driver side. Later, when I do the fuel can mount I may make it like yours m-37bruce, That looks neat and I can use some of the same parts I made.
Tomorrow will work on cowl vent. Hope to get it all on and working, all seized up at the moment.
F18hornetm
Re: 1953 M37
Some good progress today, Got the dash all sanded and primed. Had to weld up about 10 screw holes in the dash that I'm sure were not there originally. Its amazing how many holes get drilled in something that's 63 years old. I did leave all those that looked like where a data plate should go.
I found some weather stripping to put on the cowl vent that seemed to work well. Finally got cowl all primed and sanded along with each front cab corner. Getting real close to painting cab tub now. Probably one night this week I hope, then on to rear bed.
Re: 1953 M37
Sounds good, I am working on my bed and tailgate as well. I'm sure you will finish before me?
F18hornetm
Re: 1953 M37
Finally got some more done. Only had chance to do a little over weekend. but did manage to get the cab tub painted tonight. Looks good at least in the shop. Will know better once outside in the sun. Have plenty of light in shop but painting requires even more so I usually paint outside. I only paint equipment and old military trucks so outside suits me better. Try to post a pic tomorrow.
F18hornetm
Re: 1953 M37
IMG_2039 - Copy.JPG (199.57 KiB) Viewed 6740 times
F18hornetm
Re: 1953 M37
IMG_2060 - Copy.JPG (165.67 KiB) Viewed 6738 times
Not worked on old girl much. But have got a few things done. Managed to do a bunch of body work on rear bed. Not perfect but pretty good. Dents and dings show character especially for an old truck. Got the bed painted on mounted. I may never get this truck done at this rate :D
