farm truck rustoration
52PLOWERWAGON
Re: its rebuild time
Post by 52PLOWERWAGON »
that's what ive read
I don't like the look of that
Thanks,TRAVIS
1952 M37 FARM TRUCK
1941 WC RATROD
Yooper52
Post by Yooper52 »
Just go with OD green Trav :D it'll match the rest of the truck.
52PLOWERWAGON
I am putting a racing cam in my engine so I was thinking hemi orange
but I will probably go with OD green
Thanks,TRAVIS
1952 M37 FARM TRUCK
1941 WC RATROD
Yooper52
Post by Yooper52 »
Almost any color would be better than silver. at least in my opinion.
52PLOWERWAGON
you have to remember that silver is historically correct :wink:
but if I wanted a correct truck I would be about 10 to 15 K in debt already :shock:
Thanks,TRAVIS
1952 M37 FARM TRUCK
1941 WC RATROD
52PLOWERWAGON
my uncles boss installed my cam bearings 8)
and my uncle steam cleaned my block :D
and there was chunks of cast in my water jacket :shock:
but they look like they are not part of the block we are thinking they are from the sand mold
Thanks,TRAVIS
1952 M37 FARM TRUCK
1941 WC RATROD
52PLOWERWAGON
fished out cast chunks out of water jacket
valve guides in and I saved my old intakes
Thanks,TRAVIS
1952 M37 FARM TRUCK
1941 WC RATROD
52PLOWERWAGON
I got my valve seats ground
tried to install my new cam and the hub on the cam is 1 1/8
my old one is 1 1/16 so the keyed triangular piece that the cam gear bolts to doesn't fit
I'm at a stand still right now :(
but I'm going to pull the front cover off my extra engine and see if I might have one
other wise I'm going order one on Monday
if vpw doesn't have one ill have to have to have mine machined out
Thanks,TRAVIS
1952 M37 FARM TRUCK
1941 WC RATROD
52PLOWERWAGON
no progress today
but we got some wood to keep the garage warm :)
Thanks,TRAVIS
1952 M37 FARM TRUCK
1941 WC RATROD
52PLOWERWAGON
going to order my part today :)
Thanks,TRAVIS
1952 M37 FARM TRUCK
1941 WC RATROD
52PLOWERWAGON
vpw says they have never seen a 1 1/16 cam hub :shock:
and last part is ordered :D
Thanks,TRAVIS
1952 M37 FARM TRUCK
1941 WC RATROD
Travis,
So why do you have a 1 1/16" diameter cam hub? What is the remedy?
52PLOWERWAGON
T. Highway wrote:Travis,
because my grandpa measured wrong :roll: :lol: :lol: :lol:
my part to resolve the problem came today :)
more progress tomorrow
Thanks,TRAVIS
1952 M37 FARM TRUCK
1941 WC RATROD
52PLOWERWAGON
cam is in
6 valves are in
freeze plugs in
re-insulated the wiring
I need a wiring diagram so I can figure out what is what
what is the best way to prime an oilpump
Thanks,TRAVIS
1952 M37 FARM TRUCK
1941 WC RATROD
Yooper52
Post by Yooper52 »
Is it a gear type pump driven by the distributor? If it is open up the pump and put some assemble grease in there where the gears are. That way it'll have some suction and draw in the oil.
