farm truck rustoration
52PLOWERWAGON
Post by 52PLOWERWAGON »
i started my rebuild Saturday
had engine and tranny out today
engine is now on stand and i dragged in my extra engine
parts should be here tomorrow
cant wait
Last edited by 52PLOWERWAGON on Mon Dec 05, 2016 10:57 am, edited 3 times in total.
Thanks,TRAVIS
1952 M37 FARM TRUCK
1941 WC RATROD
52PLOWERWAGON
Re: its rebuild time
my parts came and I got the oil pan and head off today
only strange thing so far is a broke off tap in the block and a hole that was welded up in the side of the oil pan
52PLOWERWAGON
pulled a rod main and piston everything is standard
and its gonna stay that way
looking at having the head milled down
how far is recomended
Hi Travis,
It really depends on "if" and how much the head has been surfaced during a prior rebuild(s). Measure your valve clearance and proceed with caution.
52PLOWERWAGON
thanks bert ill measure them
if I slide a hi performance cam in my engine will I get a different reading ?
Thanks,TRAVIS
1952 M37 FARM TRUCK
1941 WC RATROD
Travis,
You will need to have the block done (assembled) before you try to get measurements. If you measure it now with worn cam lobes, you will have a false sense of clearance and end up possibly bending something.
52PLOWERWAGON
thanks bert I'll be ordering the rest of my rebuild parts by the end of next week
hopefully including a custom ground hi performance cam shaft :twisted:
Thanks,TRAVIS
1952 M37 FARM TRUCK
1941 WC RATROD
52PLOWERWAGON
question :
how do you remove valve guides
Thanks,TRAVIS
1952 M37 FARM TRUCK
1941 WC RATROD
52PLOWERWAGON
just ordered the rest of my rebuild parts
even a high performance cam shaft :twisted:
Thanks,TRAVIS
1952 M37 FARM TRUCK
1941 WC RATROD
Drew M.
Post by Drew M. »
Remove guides by press/punch them down into valve cover area. Then hit them on side to break off lower half of guide before driving remaining piece of guide down bore. You have to break it b/c not enough room for it to drop out without hitting valve spring base.
I made the tool from round stock.
52PLOWERWAGON
my uncle has an air chisel bit for valve guides
will that work
Thanks,TRAVIS
1952 M37 FARM TRUCK
1941 WC RATROD
Drew M.
Post by Drew M. »
Guides are very hard/brittle - they break surprisingly easily when hit from the side. As for the install tool - an punch tool with an o.d. near the same size as the valve guide i.d. with a washer that sits against the top of the guide works well to drive out old guides. The guides have a taper on the o.d. - install them the right way/height.
52PLOWERWAGON
I am going to strip my block so my uncle can steam clean it
Thanks,TRAVIS
1952 M37 FARM TRUCK
1941 WC RATROD
52PLOWERWAGON
block is stripped and valves are ground 8)
what color should I paint the engine ?
Thanks,TRAVIS
1952 M37 FARM TRUCK
1941 WC RATROD
isaac_alaska
Post by isaac_alaska »
Factory was silver I believe... I could be wrong.
Isaac
Fairbanks, AK
Civilian WM300 on DC3 tires
'52 M37 on 11x16 Michelin
Photo Gallery
