Replacing seat covers
Hello, I am replacing the seat covers on my M soon. What is the easiest way to get the seat backs off? Thanks!
Re: Replacing seat covers
Well, the passenger seat should just lift vertically up, its held on by 2 loops over 2 tabs welded to tub. The drivers seat has a couple bolts you should be able to remove if you compress the seat bottom and look at bottom edge of seat back. This is unless yours was modified
Rick
Rick
Both drivers and passenger seat backs hook at the top and have two bolts at the bottom.FL-M37 wrote:Hello, I am replacing the seat covers on my M soon. What is the easiest way to get the seat backs off? Thanks!
Driver seat bottom has two bolt underneath in front
The recover is pretty straight forward.
Tom
"47" WDX WW
"52" M37 WW
"54" Willys M38A1
"65" M35A1 WW
To Many Others
"52" M37 WW
"54" Willys M38A1
"65" M35A1 WW
To Many Others
Thanks fellas,
I jostled and pulled a bit, but didnt want to break anything, this tells me what's next. My OP tent halves came today, Ill go give it a try. Thanks again!
That wasnt bad at all, once I knew where to look, I'll post some pics of the final product.
- pwrwagonfire
- SSGT
On this topic...can anyone show how the passenger seat bottom is supposed to stay in position? My truck came to me half dilapidated, I cant figure it out!
-T
-T
I can't post a picture, but on my trucks, there is a stud on the front passenger side corner that fits into a matching hole in the plywood and the latch on the front of the seat to hold it in place. Maybe someone else can post a picture to show what and where. If yours has nothing left, it would be easy to figure out something similar.
Jess
Jess
I know exactly what you are talking about and my truck didn't have one on either side.
Well timing is everything-I was just posting my front clip pictures and saw this post so I headed to the garage and snapped this one-mine has a single stud (top of photo), and the latch in front.
- pass seat cushion latch and stud.JPG (27.1 KiB) Viewed 2014 times
- pwrwagonfire
- SSGT
Cal_Gary wrote:Well timing is everything-I was just posting my front clip pictures and saw this post so I headed to the garage and snapped this one-mine has a single stud (top of photo), and the latch in front.
Thanks! I have that little latch...it just presses into the bottom on the seat cushion then? I will have to see what I can do when the seat gets back from being re-covered. I worry my seat bottom may be too worn out!
-T
No, there is a little metal latch attached to the seat bottom that the spring clip looks onto. I don't have one so I can't post a picture.
