Serial Number Help
colbanister
Serial Number Help
Post by colbanister »
On my Dodge M37 the Serial Number does not fit in the range so when I try to register it on this site it says the serial number is invalid.........does anyone know why mine does not fit in the range given? Please help :roll:
Dodge M37 BI WW
Contract Number DA-20-018-ORD-23508
Ser Number 2661-88060
Del Date 7-63
Rod
colbanister
Re: Serial Number Help
Also on according to my data plate it says with winch. The refences I have show that for that contract a total of 14,059 were built and were all without winch. and none were w/w :?:
Rod
What is the number and where did you get it, from the frame?
colbanister
Carter wrote:What is the number and where did you get it, from the frame?
the frame says 266188060
the data plate shows 88060
Rod
cuz
Post by cuz »
Looks like someone has dickered with your data plates. Use only the frame serial which is for a 1962 unit and do not enter a DOD. Many reasons for the dash plate anomaly. Often the dash plates are missing and the titled year may have been 63 do someone made up a 63 data plate with the 62 serial number.
colbanister
cuz wrote:Looks like someone has dickered with your data plates. Use only the frame serial which is for a 1962 unit and do not enter a DOD. Many reasons for the dash plate anomaly. Often the dash plates are missing and the titled year may have been 63 do someone made up a 63 data plate with the 62 serial number.
I tried this and I keep getting this error message.
M37 Registry
Add New Record
Error: Record not added
Invalid Serial Number: 266188060
Serial Number 266188060 is not a valid G741 serial number
Rod
m-11
Post by m-11 »
Your contract number was built betwen 1961-1963. How clear is the frame stamp? You could strip the paint off and see if someone overstamped the original number. The 88 could have been 33.
colbanister
m-11 wrote:Your contract number was built betwen 1961-1963. How clear is the frame stamp? You could strip the paint off and see if someone overstamped the original number. The 88 could have been 33.
The number on the frame is pretty clear and the data plate also shows the same number 88060
Rod
marc8_2
Post by marc8_2 »
You should post some picture
colbanister
marc8_2 wrote:You should post some picture
Dodge M37 B1 Data Plate.jpg (17.58 KiB) Viewed 3616 times
Rod
colbanister
SN on Frame.......Kinda hard to tell from pics........
Frame SN.jpg (35.34 KiB) Viewed 3616 times
Rod
Looks like 236138060 to me....
colbanister
Cal_Gary wrote:Looks like 236138060 to me....
it could be it is real hard to see those middle numbers.......I am going to try that and see if it works....thanks
Rod
colbanister
Nope........didn't work.... :?
Rod
m-11
Post by m-11 »
Looks like 266138060
