dodge m37 marine corp hood handle
nutsfor59
Post by nutsfor59 »
hi,does anyone out there know the dimensions for the hood handle added in marine m37's ?? diameter of rod ,width,etc,thanks
Frank Irons
Re: dodge m37 marine corp hood handle
Post by Frank Irons »
I believe these modifications were done with what was available. My truck, USAF, has a hood handle made from 1/4 diameter rod.
Frank
Cav Trooper
Post by Cav Trooper »
i tried this over on SS Soldiers and couldn't get the attachments to work so, I'll try it here. The attachments here won't let me upload the jpg of the drawing so, I still need an email address to send it to. I'll try it separately here.
HHT 2nd ACR
1967/68
Chu-Lai, S. VietNam
1969
Cav Trooper
nutsfor59
Post by nutsfor59 »
hi,i like the photos but where on earth would i get those cone shaped pieces at the base of the handle ?????,i hope this isn't more trouble than it's worth, thanks
powerwagontim
Post by powerwagontim »
The hood handle on mine is simply a piece of rod bent like in the picture, but instead of the fancy little cone pieces, mine just has nuts on them, outside the hood and inside. I like the cones better!
Tim
wvcharlie
Post by wvcharlie »
I picked up a hood handle from Vintage Power Wagons when I was out at the Power Wagon Rally last year. We had the run of the yard. They had quite a few M37s with hood handles and I was surprised at the differences in the handles, even the height. The one I got (as did most) just had washers and nuts on the top of the hood.
Charlie
64 M38A1
65 M37
68 M725
101st ABN Veteran
powerwagontim
Hi Charlie,
Getting any closer to the tonneau cover project? I mounted the rope hooks for the top yesterday and was thinking about you!
Tim
repealThe17th
Post by repealThe17th »
The handle on mine is just 1/4 inch rod, threaded on the ends. Hex nuts top and bottom hold it in place.
nutsfor59
Post by nutsfor59 »
hi,thanks to all of you for the help !!!
wvcharlie
Post by wvcharlie »
powerwagontim wrote:Hi Charlie,
Tim
Tim,
I am still waiting to get my truck back from the guy who is helping me put the 318 V8 in. Now that the weather has improved, We can wrap that project up. I think the tonneau cover will be a great idea and other members may be interested when I get it finished. I will let you know my progress.
Back to topic, the above pictures are what most all of the handles in the yard at VPW looked like. The ones with the neat ferrules must be an early version before they decided it was to much expense and just went with threaded rod.
Charlie
64 M38A1
65 M37
68 M725
101st ABN Veteran
