M37CDN Carb
rdwhite
M37CDN Carb
Post by rdwhite »
Was the B&B ETW1 carburetor used on the 251 engines in Canadian M37's? If so, were the same metering jets and rods the same as used on the 231 engines?
M37UK
Re: M37CDN Carb
Post by M37UK »
According to the EME manual, the carb should be an E9-D1 but I have the ETW1 on my M37CDN.
M37 Carb data.jpg (120.04 KiB) Viewed 860 times
Stu
MVT UK
SMVG Scotland
rdwhite
Re: M37CDN Carb
Post by rdwhite »
Thanks for responding. Is your ETW1 stock, or did you have to jet it up for the larger engine?
M37UK
Re: M37CDN Carb
Post by M37UK »
rdwhite wrote:Thanks for responding. Is your ETW1 stock, or did you have to jet it up for the larger engine?
My carb is stock. I dont know enough about them to consider things like jetting them up.
Its a good point though, maybe someone with more tecnical knowledge could help here.
Cheers
Stu
MVT UK
SMVG Scotland
m15256
Re: M37CDN Carb
Post by m15256 »
I've switched the ETW1 from my 230 on the M56 to the 251 on the M152 and found no difference in performance.
RICK
M 152 CDN
M 56 (V41)
