Back On Line
Back On Line
Greetings, gang! I finally got my computer hooked up and running on a wireless link with my daughter's computer. It's on dial-up access, so it's a lot slower than I'm used to, but I guess it'll have to do until I can find a house with cable access. For those who didn't already know, I'm no longer in Illinois. I'm currently in Lavonia, GA, and enjoying the nice weather. It's about 38 degrees and threatening to rain right now, but it bets the heck out of the 2 below and freezing rain that they're getting back in Illinois this morning. I can get used to this!
- HingsingM37
38 degrees! Thats tropical!
Welcome back Lifer good to hear from you. Hope all is well and you are getting settled in.
Enjoy your heatwave.
Today , instead of working on the Dodge, I will be working on my daily driver installing a heater core in my unheated garage
Darn 98 Ford Ranger, I have to pull the whole dash out
It's supposed to be in the teens here in Ohio today
It's About Time
Happy New Year Lifer, glad you got the hook-up!
38 degrees hoo-haa, lucky fer you.
Welcome back!! Thought maybe your car overheated heading south. I think I would be glad to leave Illinois also, for more than 1 reason.
GA..
Lifer;
Glad you're back.
Glad you're back.
Heat
David;HingsingM37 wrote:38 degrees! Thats tropical!Welcome back Lifer good to hear from you. Hope all is well and you are getting settled in.
Today , instead of working on the Dodge, I will be working on my daily driver installing a heater core in my unheated garageDarn 98 Ford Ranger, I have to pull the whole dash out
You need to get one of those little propane powered heaters. I have a small one that I bought from Home depot. The thing is like a little rocket engine. Puts out 40K BTU. It will heat my garage to a comfortable level within about 15 minutes. I too was working out in the garage today(drilled the firewall to install heater hoses). I didn't want to work with numb fingers, so I closed the garage door and fired up the rocket engine. It was between 28 and 30 deg out. I had it fairly comfortable in there in no time. Actually wound up taking my coat off. They are well worth the money, and if you already have a propane grill, there is your source of fuel.
- SSGT
WELCOME BACK ON LINE
YOU OLD TURN COAT ,
HOPE ALL IS GOING WELL , BET YOU MISS ALL THOSE MORNINGS WHERE YOU GOT UP AND HAD TO PUT ANOTHER LOG ON THE FIRE!
LET US ALL KNOW WHEN YOU GOT THAT SOUR MASH JUST RIGHT SURE COULD USE A GOOD OLD GULP OF THAT HOME BREW NEED TO KEEP THAT BLOOD THIN OUT UP THIS AWAY!
OLD ROD BA GOYABITCH GOING TO GET HIS JUST BEFORE LONG.
Hit Duh Ground Runnin
Re: WELCOME BACK ON LINE
Did you happen to hear the dear sweet words the governor shared in this mornings interview on Good Morning America? In his words he's really getting a raw deal.anthony manzella wrote:YOU OLD TURN COAT ,HOPE ALL IS GOING WELL , BET YOU MISS ALL THOSE MORNINGS WHERE YOU GOT UP AND HAD TO PUT ANOTHER LOG ON THE FIRE!
- SSGT
