Was just wondering...
When in 4th, how much 'side-to-side' movement is in the stick (measured at the top of the gearshift)?
1-2", 3-4", none
Yeah, great technical question.
Gearshift Play: 4th
Gearshift Play: 4th
1952 M37 - Mods = Locking hubs, battery switch, 2 bank charger, PB, PS, Pertronix SSI, Elect fuel pump w/filter&pressure switch.
Planned: Seatbelts, Bimini top
Re: Gearshift Play: 4th
Some. With a brand new shifter top assembly, it is about 2".
With and old top it can be stirring the witch's cauldron. It works just about anywhere. You just have to get used to it.
Thanks. Mine moves a bit over 2" side to side. Thought that was excessive.
1st-series top covers are the worst. That little anchor pin works loose over time creating all kinds of oddball movement. Charles at M-Series does these repairs regularly.
