New Noise
Posted: Thu Apr 11, 2024 6:06 am
by greeno
Sounds like it's coming from the dizzy. I don't think it's the generator or water pump. This is at idle:
https://youtube.com/shorts/xtPJqD4p7LM?feature=share
Anybody got ideas?
Re: New Noise
Posted: Thu Apr 11, 2024 9:24 am
by ODAddict
How about the clutch area? Try depressing the clutch pedal slightly while running to see if that makes a difference.
Re: New Noise
Posted: Thu Apr 11, 2024 9:51 am
by greeno
Same noise with the clutch in or out
Re: New Noise
Posted: Thu Apr 11, 2024 1:17 pm
by ODAddict
There was a lot of competing or background noise in the video. Is it possible to separate out or filter the sound?
Could be a worn camshaft, oil pump issue, valve lifter, distributor, generator or water pump bearing, etc, but go simple first.
What about the belts? Are they in good shape?
Re: New Noise
Posted: Thu Apr 11, 2024 4:42 pm
by ashyers
Pull the belt and see if it goes away. Quick and eliminates a bunch of items.
Re: New Noise
Posted: Thu Apr 11, 2024 5:59 pm
by Rdinatal
ashyers wrote: ↑Thu Apr 11, 2024 4:42 pm
Excellent suggestion!
To me it almost sounds like high pressure air leak. Time for a quick compression test
Re: New Noise
Posted: Thu Apr 11, 2024 9:21 pm
Perhaps a manifold leak?
Re: New Noise
Posted: Sat Apr 13, 2024 7:17 am
by Murf
Go get one of those cheap auto stethoscopes and simply touch each component. When you hit the right one you will know it!
Re: New Noise
Posted: Sat Apr 13, 2024 8:27 am
by ODAddict
Excellent suggestion, Murf.
Now, I'm off to play doctor with my truck.
Re: New Noise
Posted: Mon Apr 15, 2024 6:10 am
by greeno
Same noise with the belt off, and after torquing the manifold (several nuts were loose).
Re: New Noise
Posted: Thu May 23, 2024 3:41 am
by Rdinatal
greeno wrote: ↑Mon Apr 15, 2024 6:10 am
Any luck finding the issue?
Re: New Noise
Posted: Thu May 23, 2024 6:27 am
by PoW
Yep on the stethoscope.
Many years ago at the Yuma Proving Ground DRMO, a very pretty M37 was sold with a description "engine rod knock".
A friend bought it, and it turned out the generator bracket was cracked, causing what really did sound like a rod ready to come out.
Re: New Noise
Posted: Mon Jun 03, 2024 6:43 am
by greeno
I changed the break in oil (30w) to T4 15w-40 and the noise is gone. It’s been in there 2+ years but very low miles.
Re: New Noise
Posted: Mon Jun 03, 2024 10:09 pm
Wow-I know some differentials require an additive but wouldn't think changing the engine oil alone would solve the issue.
Thanks for letting us know!
Re: New Noise
Posted: Thu Jun 06, 2024 5:45 pm
by John Mc
Poor man's stethoscope: get a piece of old broom handle or a similar size metal bar. Put one end on the engine part in question, and the other end against your ear. Works well to isolate sounds from different parts of the engine.
