New Noise
greeno
New Noise
Post by greeno »
Sounds like it's coming from the dizzy. I don't think it's the generator or water pump. This is at idle:
https://youtube.com/shorts/xtPJqD4p7LM?feature=share
Anybody got ideas?
M37
YEAR: 1954
ODAddict
Re: New Noise
Post by ODAddict »
How about the clutch area? Try depressing the clutch pedal slightly while running to see if that makes a difference.
John Hedges
MVPA 17461
greeno
Re: New Noise
Post by greeno »
Same noise with the clutch in or out
M37
YEAR: 1954
ODAddict
Re: New Noise
Post by ODAddict »
There was a lot of competing or background noise in the video. Is it possible to separate out or filter the sound?
Could be a worn camshaft, oil pump issue, valve lifter, distributor, generator or water pump bearing, etc, but go simple first.
What about the belts? Are they in good shape?
John Hedges
MVPA 17461
Re: New Noise
Pull the belt and see if it goes away. Quick and eliminates a bunch of items.
Rdinatal
Re: New Noise
Post by Rdinatal »
ashyers wrote: Thu Apr 11, 2024 4:42 pm Pull the belt and see if it goes away. Quick and eliminates a bunch of items.
Excellent suggestion!
To me it almost sounds like high pressure air leak. Time for a quick compression test
Re: New Noise
Perhaps a manifold leak?
Murf
Re: New Noise
Post by Murf »
Go get one of those cheap auto stethoscopes and simply touch each component. When you hit the right one you will know it!
ODAddict
Re: New Noise
Post by ODAddict »
Excellent suggestion, Murf.
Now, I'm off to play doctor with my truck. :D
John Hedges
MVPA 17461
greeno
Re: New Noise
Post by greeno »
Same noise with the belt off, and after torquing the manifold (several nuts were loose).
M37
YEAR: 1954
Rdinatal
Re: New Noise
Post by Rdinatal »
greeno wrote: Mon Apr 15, 2024 6:10 am Same noise with the belt off, and after torquing the manifold (several nuts were loose).
Any luck finding the issue?
Re: New Noise
Yep on the stethoscope.
Many years ago at the Yuma Proving Ground DRMO, a very pretty M37 was sold with a description "engine rod knock".
A friend bought it, and it turned out the generator bracket was cracked, causing what really did sound like a rod ready to come out.
greeno
Re: New Noise
Post by greeno »
I changed the break in oil (30w) to T4 15w-40 and the noise is gone. It’s been in there 2+ years but very low miles.
M37
YEAR: 1954
Re: New Noise
Wow-I know some differentials require an additive but wouldn't think changing the engine oil alone would solve the issue.
Thanks for letting us know!
Re: New Noise
Poor man's stethoscope: get a piece of old broom handle or a similar size metal bar. Put one end on the engine part in question, and the other end against your ear. Works well to isolate sounds from different parts of the engine.
