Hello.
New to this forum, so if this is not the correct place for the following question, please advise me which area I should post my question.
Can new valve seats be installed in the 230 cu in flathead in my M37 while the engine is still in the truck?
Thank you for any advice.
Valve seat in 230 flathead
Re: Valve seat in 230 flathead
Well, there are no intake seats per se. So you can grind them in position with a seat grinder The exhaust CAN be done insitu, but you will need the necessary tools and skills to do so. Not very common anymore.
rigger1968
Thanks. Sounds like it is beyond my skill level. Think I will have a shop do the work.
Sometimes you have to pay the man...
rigger1968
True. A smart man knows this.
How bad are the seats? Are you sure you need to replace them? Any photos?
If they are bad enough to need new ones I guess you could manage to pull the exhaust seats with the block in the truck, but you'd be stuck with the intakes without some creative machining techniques.
If the seats are toast I suspect the engine needs to be rebuilt as well. When you machine the deck you'd have to re-cut the seats anyway and I bet you'd be OK. The height of the seats would drop, but that's not a big deal in these. I'd be surprised if the exhaust seats need to be replaced, they're pretty darn hard!
