I need to have the brake pedal modified for the type of power brakes being installed. A search on the .net on how to remove it turned up zero. Even a search here, nada...
Looking at the IPB shows the pedal shaft and bracket. How is the shaft held in the bracket? I don't see a retaining clip or bolt.
Do I need to take the bracket off the frame and then slide the shaft out of the bracket towards the frame?
Brake Pedal Removal
Brake Pedal Removal
Re: Brake Pedal Removal
Look in the body and chassis manual. Procedure is there.
Thanks. The clutch pedal shares the same bracket and shaft. I found where the retaining collar clamp is.
