Hi All
I have read several posts on severwl forums about rebulding a LU4 winch.
I haven't seen any mention except in the TM of the small pins that go through
The drum bushings. Are people not installing these? I think our winch has had the bushings replaced and only had a pin in one of the bearings.
Winch Drum Bushing Pins
- sturmtyger380
Re: Winch Drum Bushing Pins
I don't remember pins going through the bushings that are inside the drum. But then I didn't replace my drum bushings I bought a new drum. I still have the old drum and will take a look at it. But I see now in the manual it talks about removing both, (TT) and (BJ). But doesn't say how to do it. I haven't seen any of these pins offered anyplace. And it plainly says to discard them.
The only function I see them performing is to keep the bronze bushing from rotating inside the drum under pressure from a pull.
I used the press at the Ft Jackson auto shop to insert mine. It was a tight fit, can't imagine the bushing would be likely to spin with a pull. hal
The drum of my winch has pins in both bushings. I didn't need to replace the bushings, but if I did I would probably use bearing and sleeve retainer instead of the pins. The issue I see with using the pins is that you'd likely have to drill & ream another hole in the bushing/drum for the new pin, plus fab up the pin.
Thanks for the replies. I'm thinking these are normally left out.
