Winch Chain
1952m37lw
Winch Chain
Post by 1952m37lw »
I am in the process of adding a winch to my m37. I am curious if anyone could tell me the length and thickness of the chain at the end of the winch cable. Thanks.
Re: Winch Chain
Mine is oversized so I can't help you there. Anyone with the standard winch chain out there who can help?
sturmtyger380
Re: Winch Chain
Post by sturmtyger380 »
You ask a good question. I will put a winch on my M37 once it's done. I collected a bunch of notes on the wire rope but no one can tell me the exact length and weight of the chain. I have heard that is is 5 feet long. No one seems to have any. I haven't seen any at shows. Saw an old one offered once online for $500. I am not spending that much on an old chain with a hook that may or may not be correct.
I gave up and got this that I will use: eBay item number: 265188681323
On the wire rope, the Army started out for the wire rope on the LU-4 with 150' of 7/16.
Then in Jan 1957 changed to 200' 1/2 wire rope.
Then in June 1963 changed to 150' 1/2 wire rope. The extra 50' was too much for the drum to hold.
ez8
Re: Winch Chain
Post by ez8 »
I'm rebuilding an original winch right now. My cable and chain are intact, but I don't know what measurements you need.
Let me know what and how you want it measured and I'll get it done some night this week.
1952m37lw
Re: Winch Chain
Post by 1952m37lw »
I would like to know the length of the chain from the cable to the hook.
sturmtyger380
Re: Winch Chain
ez8 wrote: Mon Dec 05, 2022 5:48 pm I'm rebuilding an original winch right now. My cable and chain are intact, but I don't know what measurements you need.
Yes, please solve this mystery. We need pictures too. :lol:
Murf
Re: Winch Chain
Post by Murf »
Murf
Re: Winch Chain
Post by Murf »
Total length of the assembly is 48"
Chain section is 7/16" and 43" long.
Eyelets at the ends of the chain are 3" (7/16" thick)
Hook is stamped " AMERICAN CHAIN AND CABLE" "DROP FORGED"
The original assembly is all 1 piece, no shackles.
Hook is 7".
Please remember, these number aren't just going to "add up" as the links/eyelets/hook overlap in their connections.
Hope this helps!
ez8
Re: Winch Chain
Post by ez8 »
Neat. Here's what I came up with. Ignore my cool orange shoes and all the cat hair. :oops:
Overall Chain length (excluding the large links that connect to the hook and the wire connection): 40.5"
Each link is roughly 10.5mm thick, 34mm wide, and 50mm long
sturmtyger380
Re: Winch Chain
So, that comes out to 4 feet long not the 5 feet that I have always heard.
