M37 for Sale needs work price reduced
burmafrd
Post by burmafrd »
1952 Dodge m37 as a 230 cubic inch Flathead 6 cylinder 4-speed manual transmission to speed transfer case Dodge iPod axles with 583 gears engine runs strong has been converted to 12 volt with a single wire GM alternator axles have been rebuilt IE King pins bushings inner and outer axle support bushings in and outer axle seals wheel bearings wheel cylinders brake shoes brake lines fuel tank has been removed clean reinstalled new fuel lines to the engine remanufactured fuel pump from vintage power wagons and a rebuilt carburetor has 24,000 lb rear facing PTO driven winch with a homes wrecker arm in the bed the truck also comes with a Holmes bantam wrecker recovery boom that is black in color $8500 solid. serious inquiries only no trades
burmafrd@yahoo.com for more information
Located in Tooele Utah
Yellow M37.jpg (93.04 KiB) Viewed 8149 times
