What do I have to do to replace the window crank handles? My driverside crank had the metal part fall off and was replaced with a screw and bit of plastic.
Also, if anyone has a spare, please let me know! Mine is a 51 if they changed later...
Window cranks
Window cranks
1951 M37 w\w
Marcus in NC
Marcus in NC
Window Cranks
There is an escutcheon behind the crank handle(door handle is the same), it should have a spring loaded inverted cup on it, compress the cup, insert steel pin, allow cup to expand, BAM, your finished. If your missing the correct pieces, John @ Midwest has them, AB Linn too, all of the usual suspects have them, or maybe someone here on the Forum will come to your rescue?
I Might have a picture somewhere also?
Good Luck,
Good Luck,
