I just purchased an 8 sided socket off epay.
It doesn't have an attachment point for a socket wrench,
just two holes on opposite sides of the socket just below the lip.
Obviously you stick a bar through here.
Here is my question.
If i took a two foot cheater bar and attached a pull scale to the end.
Then doubled the reading on the scale, would this be accurate
enough to set my 100# preload. My guess is that this would
be fine.
Tnx.
J.B.
8 sided socket
Me being the perfectionist that I am, here's what I would do. These sockets are available from NAPA at a very reasonable cost. They are set up for rachet use so using a torque wrench isn't an issue. I'd pass the socket you have on to someone who wants an original & get one I could use with a torque wrench. You could go to a machine shop & get a piece made to adapt it & weld it on, but it would no doubt cost more than buying a correct socket from NAPA. Our situation here is very different from yours, we are working for the public therefore I want things to be adjusted as near picture perfect as possible, this is why my view is what it is.
Last edited by MSeriesRebuild on Sun Jul 06, 2008 1:38 pm, edited 1 time in total.
Nickathome
Socket
Is it possible you can drill a center hole, then square it up with a file, etc to fit a torque wrench? MIght be worth a try if you don't mind modifying the socket.
TRACTORg25
Don't Forget Sears
I bought a new breaker bar & socket from sears, 3/4 " drive effortless lug removal. An adapter and the whole thing fits my torque wrench.
- sbaumgartner
TRACTORg25
- jeeptech2000
