Fuel Pump ID and rebuild or replacement help needed
signsup
Post by signsup »
fuel pump 2.JPG (26.59 KiB) Viewed 569 times
fuel pump 1.JPG (30.46 KiB) Viewed 569 times
Have a WWII Dodge WC 56 Command Car with a post war 230 engine in it. Getting gas into crakcase and oil and fuel pump diaphrame is suspect. Appears to be civilian fuel pump as it has a glass bowl. But all the replacement pumps I see images of, the cam arm is different and I really would like to keep this pump as all the hard lines are routed correctly to it, so a rebuild kit or a plug and play replacement would be ideal.
Any idea what this pump is? Or can you recommend a bolt on replacement? No ID on pump other than rebuild tag with date or number, but not a part number.
Any help greatly appreciated.
signsup
Re: Fuel Pump ID and rebuild or replacement help needed
Post by signsup »
Got a new one coming from Midwet Military. Thanks to all who helped.
