Rebuild photos needed
bobcat1/178th
Does anyone have rebuild progress pics they can share....TM's just don't show everything clearly....Looking for pics of the frame brackets and mounts. Such as front fender mounting brackets. Trying to get everything mounted to the frame that's needed before dropping engine, trans and then cab....Transfer case already on as well as brake/fuel lines & rear harness....
Re: Rebuild photos needed
when I took my M37 apart and rebuilt it, with help from others and Charles T, I took hundreds of pictures of just about everything, which side of a linkage a washer went, where a wire went over or under some other part, and on and on. I can put them on a USB and mail it to you if you will pm me with your address. It might take me a few days. Many are before and after a repair or fix. If you need a different pic now of how things are on my truck, I can shoot new ones and post them here. Hal.
You could look at my thread, "1954 M37 Rebuild thread" just below you on this list.
